Installed the bottom skin with the approx 150 rivets. Had to extend the tail skid hole a little to eliminate skin contact. Installed the tail skid fairing.
Installed the autopilot altitude hold servo and connected the linkage and electical connector. Applied torque seal on the outboard heads of the mounting screws to monitor for loosening.
Tightened the jam nuts on the aft flap linkage and applied torque seal. Installed the MS24665-132 cotter pins on the bolts.
Shortened the left aileron hinge pin slightly, drilled for the MS24665-5 cotter pins and installed the cotter pins on the left and right ailerons.
